Perform the following procedure to view Node Alias protocol information.
Detailed information displays for IPv4, IPv6, BGP, VRRP, and broadcast UDP protocols only.
- Select Node Alias.
- Select the Protocol Info tab.
Protocol Info Field Descriptions
Use the data in the following table to use the Protocol Info tab.
Name |
Description |
SourceMacAddress |
Displays the source MAC address. |
Isid |
Displays the I-SID. |
Vlan |
Displays the VLAN. |
InterfaceIndex |
Displays the receiving port or MLT interface. |
Type |
Displays the protocol type. |
Value |
Displays additional details regarding the used protocol, such as:
Isid Value |
Displays the I-SID value of the I-SID-to-VLAN assignment. |
LastLearnedTimer |
Displays the timestamp when the client was last updated on the port. |
